Les dejo las tablas para elegir el talle de bici. Este obviamente aplica solo a Specialized. Los que tengan las tablas para otas marcas, por favor publicarlas.
encontre esto que si bien habla sobre trek, se aplica a todas las marcas. (es para los que entiendan ingles)
Trek makes both road bicycles in a range of frame and wheel sizes to accommodate cyclists from under 5 foot 2 inches, up to 6 foot 4 inches tall. Child sizes are also available. Because physical attributes vary from person to person, even people of the same height may need bikes that are different in frame and wheel size. Saddle size, height and position, wheel size and other factors also need consideration when determining which Trek bike to choose. Ultimately, your decision will depend on how the bike feels and rides for you. Step 1Measure your height. Compare that measurement to the Trek bike size charts on the Trek website, where Trek recommends different frame sizes for various heights. This helps to narrow the size choices. If you are between sizes, Trek recommends
Step 2Visit a bike shop that carries Trek bicycles to try bikes for size. Select a bike that corresponds to the size listed on the Trek website for your height. Step 3Straddle the bike. Check the distance from your crotch to the top bar of the bicycle frame. The distance should be approximately 1 to 2 inches.
Step 4Set the bicycle saddle to the highest position possible. Sit on the bicycle saddle. Place your foot on one of the pedals in the down position. Examine the angle of your leg. If your leg is perfectly straight, lower the saddle until there is a slight bend in your leg. If your leg is bent beyond a slight angle, select a bike with a larger frame and smaller wheel size. Step 5Test ride the bike to determine if it is a good fit. If necessary, adjust the seat height, position and angle and the handlebar height and position.
